| | | Forums66 Topics128,088 Posts1,056,002 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,786 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,786 | That terminal is used to provide full battery voltage to the upstream (ignition switch) side of the coil during cranking. If your electrical system has been converted properly, there should be a ceramic resistor inline between the switch and the coil to drop the voltage to about 9 volts or a little more during normal running to protect the points. Because the load of the starter drops the voltage, it's necessary to bypass the resistor so there's a hot enough spark for a good cold start. Just connect a wire from the small terminal to the coil + terminal.
Edit: That switch was original equipment on 12 volt starters from mid-year 1955 and newer engines, but it's a bolt-on swap for the 6 volt starter switch which did not have (or need) the bypass terminal. Jerry
