ok, seein's how yer in canada i'll tell ya a potential problem.
carb icing in hi humidity,cold air.
a couple for the rest of ya, don't pick up the air from below the bumper.
higher is better.
why?
ever feel the asphalt/concrete on a 100 degree day?
12" off the ground ain't much cooler.
will it do any good?
depends on how fast if you are talking about ram air effect.
just the cooler air can let you run a little more timing(not much) before deonation.
a little more fuel(darn little).
THAT'S where the power will be if there's any to be made.
i miss obscene phone calls...
