| | | Forums66 Topics128,192 Posts1,057,350 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 | I'm installing a 3" dropped axel on my '59 235 apache. Has anyone had experience in modifying the drag link to keep it level with the pitman arm to avoid the dreaded bump steer. When building the old F*** roadsters they used to heat the steering arm and bend it lower. Can I cut the draglink and rotate the end with the steering arm balljoint to a downward position and then install it on the top of the arm instead of the bottom of the steering arm? I hate to cut the draklink but if I have it Mig welded and pinned inside of a sleeve I guess it should be ok. What do you guys have to say?
