| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | Terminal voltage while cranking will tell the tale, but only if the connections are clean and tight and the cables are big enough. 6 volts leaves absolutely no room for error where voltage drop across connections are concerned. Dropping more than 1/10 volt per connection is too much. Jerry
