| | | Forums66 Topics128,162 Posts1,056,913 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Hi Harold,
The first rear view mirror you posted looks like 2 I have that were attached to early 1941 Chevy military trucks. Even the phillips head screws match which is peculiar as they are about the only phillips head screws found on my 41 truck as it came from the factory. All military trucks of the era came with factory installed inside rear view mirrors. I can hunt down a part number if you are interested...it may help your search.
Paul
Edit...looked at the first image a bit closer, and I believe that image you posted may be from my truck since it is OD green! The third image looks like the same mirror though.
