Normally, the clutch throw-out (clutch release) bearing is sealed.
If the bearing-balls are worn, it can rattle.
If the the throw-out bearing "arm" is loose (worn ball, for example), it could rattle.
If the throw-out bearing arm spring is loose/missing, you will hear rattling.
http://chevy.oldcarmanualproject.com/parts/1929_54/113.HTM
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0689.htm
