| | | Forums66 Topics128,165 Posts1,056,989 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,867 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,867 | The unlimited class tractor pull engines I've worked with had a lifespan measured in minutes at full throttle at best- - - - -some of them were scrap iron after (or during) one pull. One notable example was a "426" hemi I helped build that ended up at 547 cubic inches once we filled the block with epoxy and bored the cylinders out for flanged sleeves that left a stripe of epoxy showing down the front and rear of all the cylinders. My guy won the first three pulls he entered, running fuel injection without a blower. Then he got greedy and installed a 40% overdrive blower without reducing the static compression ratio. He (almost) made a full pull at Hazel Green Alabama before the engine blew the crankshaft out the bottom in three pieces. The cylinder walls held, though!
Rattle and Snap plantation in Columbia Tennessee ran two jet black International tractors, "Black Widow" and "Old Rattler". I'll bet Evan has encountered one or both of them somewhere along the tractor pull circuit! Jerry
Entire Thread
Oil pump - high presure, or volume, and why?
| Detroit Iron | 10/27/2018 3:41 AM |
Re: Oil pump - high presure, or volume, and why?
| panic | 10/27/2018 3:51 AM |
| Hotrod Lincoln | 10/27/2018 4:16 AM |
| Detroit Iron | 10/27/2018 4:21 AM |
| Detroit Iron | 10/27/2018 4:28 AM |
| Hotrod Lincoln | 10/27/2018 4:48 AM |
| Joe H | 10/27/2018 2:02 PM |
| brokenhead | 10/27/2018 4:35 PM |
| 78buckshot | 10/28/2018 1:55 AM |
| coilover | 10/28/2018 4:31 PM |
| Detroit Iron | 10/29/2018 3:38 PM |
| Hotrod Lincoln | 10/29/2018 3:54 PM |
| coilover | 10/31/2018 8:11 AM |
| Hotrod Lincoln | 11/01/2018 12:05 AM |
| brokenhead | 11/02/2018 11:04 AM |
| Hotrod Lincoln | 11/02/2018 12:07 PM |
| Grigg | 11/02/2018 1:03 PM | |
