| | | Forums66 Topics128,165 Posts1,056,989 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 1,994 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,994 | HRL, correct me if I don't have this right but rule of thumb has been 10psi/1000RPM. Is that still safe to assume. I remember the older Detroit Diesel's, 7-8psi at hot idle and 35-38 psi wound out. I agree with you, more pressure/volume is wasted energy.
1957 Chevrolet 5700 LCF 283 SM420 2 speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto, 1978 Yamaha DT175, 1999 Harley Davidson Softail Fat Boy
Entire Thread
Oil pump - high presure, or volume, and why?
| Detroit Iron | 10/27/2018 3:41 AM |
Re: Oil pump - high presure, or volume, and why?
| panic | 10/27/2018 3:51 AM |
| Hotrod Lincoln | 10/27/2018 4:16 AM |
| Detroit Iron | 10/27/2018 4:21 AM |
| Detroit Iron | 10/27/2018 4:28 AM |
| Hotrod Lincoln | 10/27/2018 4:48 AM |
| Joe H | 10/27/2018 2:02 PM |
| brokenhead | 10/27/2018 4:35 PM |
| 78buckshot | 10/28/2018 1:55 AM |
| coilover | 10/28/2018 4:31 PM |
| Detroit Iron | 10/29/2018 3:38 PM |
| Hotrod Lincoln | 10/29/2018 3:54 PM |
| coilover | 10/31/2018 8:11 AM |
| Hotrod Lincoln | 11/01/2018 12:05 AM |
| brokenhead | 11/02/2018 11:04 AM |
| Hotrod Lincoln | 11/02/2018 12:07 PM |
| Grigg | 11/02/2018 1:03 PM | |
