I am too far away to directly help you on this, but if you have any sample of the color you are looking for, it should be able to be matched. I used to sell Sikkens paint and have colormap books that have actual painted blocks with holes in the center for matching colors. They are organized by color and shade, not year and make like most books, which makes it much easier to match colors. I recently helped a guy at work get a late model code for his 29 Harley that he is restoring. If there is a local paint store that sells Sikkens, they should be able to help you out if you have any kind of sample. Some brands also now have computer matching, which I have not had as good of luck with. Anyway, good luck.
