2 members (TUTS 59, Mike B),
126
3
Mod | | | Forums66 Topics128,283 Posts1,058,504 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | I have found the same rear housings on both trucks and cars. The speedometer drive gear determines which type driven gear to use. An example would be: 55-59 truck with a 3:90 rear end would use a 19 tooth metal gear. It has a corresponding drive gear which is larger than used in a passenger car. If the same truck had a car transmission, it would probably use a 22 tooth plastic gear. The corresponding drive gear would be smaller than the truck drive gear to accommodate the larger plastic gear. Subsequently, if it has a car drive gear it won't turn a truck driven gear. Pick up a plastic gear - many on ebay for about $12 and see if it fits. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
