KevFF217; Do you think the "oil leak" is coming from the grease cup on the distributor, or could it be engine oil ? What is your approximate oil pressure on your dash gauge for the engine oil PSI when the motor is running? Enclosed is a diagram of a transverse elevation for a 1936 206cu motor , hope it assist you.
