0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Those spring mount brackets on the rear axle housing are correct - they allow pivoting when the rear springs flex. https://www.chevsofthe40s.com/detail/8661/Chevrolet_Bushing_Bolt_With_Nut_Rear_End_To_Spring.html"These are bushings with bolts, nut. rear end pivot at leaf spring on a 1/2 ton pickup." The bolt that goes through the bushing is often hard to remove. Also, you might have to press out the old bushing from the cast housing, and then press/drive in the new bushing. | | |
