7 members (cmayna, 55shaker, Gray_Ghost, Otto Skorzeny, Hotrod Lincoln, MikeE, 1 invisible),
131
3
Mod | | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 105 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 105 | I had hard starting issues for a while and my truck was parked by the PO for at least 19 years before I got to fiddle with it. You mentioned using ether to try to start it.... Everything I've read here says that ether/starting fluid is about the worst thing you can put in an engine, especially for repeated uses on something that won't start... The most I did was dump a little gas down the carb, before I got the ignition sorted out. | | | |
Entire Thread
Newbie, Stuck Starter 37 pu 216
| bugnut | 09/19/2018 11:21 AM |
Re: Newbie, Stuck Starter 37 pu 216
| 3B | 09/20/2018 2:47 AM |
| bartamos | 09/20/2018 4:14 AM |
| Pre '68 Dave | 09/20/2018 2:04 PM |
| bartamos | 09/20/2018 6:25 PM |
| bugnut | 09/20/2018 7:39 PM |
| Sulli | 09/21/2018 2:43 AM |
| bartamos | 09/21/2018 5:46 PM |
| bugnut | 09/26/2018 11:35 AM |
| bugnut | 10/17/2018 8:04 PM | |
