| | | Forums66 Topics128,214 Posts1,057,486 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | The only difference I'm aware of on the "high water pump" engines like the 216 and the spray-oiler 235's, plus the 1954 and early 55 full-pressure 235's is the width of the fan belt. Some of the 53-up 216's and 235's had a 3/8" wide belt, and the pulley on the high-mount pumps are all press-fitted to the shaft- - - - -no way to swap pulleys. As long as you find a pump that has a belt width to match your balancer and generator, it should bolt on and work OK. Jerry
