You can look and look no supplier has this item .But if you look at your inner fender the back seal that is stapled on is the same as the piece you are looking for, fits perfect. Hard to staple in ,I used weather strip glue and a few small rivets to hold in place.Just buy the rubber for inner fenders and cut to fit . It is easy to install if you take the rivets out, put rubber on and then reinstall ,with some round headed blind rivets
!956 Gmc Napco 4x4 Factory line built .
