| | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | You should not have gotten more than about 1 volt at the generator armature terminal with the field wire disconnected. Something, possibly internally in the generator, is allowing the field circuit to find a ground. Check the insulator at the "F" stud in the generator to see if it is contacting the housing. The only place you should get a ground for the field circuit is through the regulator points. I would consider 1/8 turn of the regulator adjusting screw to be a HUGE change. Jerry
