| | | Forums66 Topics128,052 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My gas tank was almost empty. I filled it up over the weekend. Now my gauge does indicate full...but when the ignition is off it continues to register full. I thought it was supposed to indicate empty whenever the ignition is off regardless of the amount of gas in the tank. Am I correct and what is the likely problem? Thanks. Did it work normally prior to your fill up? Did you make any wiring changes?
