I went with EPAS electric power steering, 53 3100. All the performance sports cars are using it and I believe a lot of American cars. Easy install, model specific. Just cut a chunk of steering column out, bolt it in and run power. Have to flat spot the shaft. No steering box, power steering pump, hoses, brackets, pulleys or belts. It's adjustable on the fly as to how much power you want so you don't lose the "feel" of the road. It's worth looking into at the least. The motor is about the size of a pop can and tucks up under the dash. It torques off the column so no mounting brackets. It even works with the engine off. You could literally install it with a hacksaw and a file.
Old enough to know better, too young to resist.
