| | | Forums66 Topics128,078 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Broken rings usually won't drop the compression all the way to zero. That takes a badly burned or stuck valve, or maybe a hole in a piston. Air pressure at the spark plug hole with the piston near top dead center on the compression stroke will pinpoint the source of the leak. Put the transmission in gear and set the parking brake, or clamp the flywheel to keep the air from turning the crankshaft. Jerry
