1 members (‘37ChevyPU),
86
3
Mod | | | Forums66 Topics128,211 Posts1,057,476 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 16 New Guy | | New Guy Joined: Apr 2008 Posts: 16 | There is no point in checking the dwell in an HEI system because the ignition module keeps adjusting it with RPM. The HEI will either work or it won't and it seems to be working.
If your fuel economy dropped but the fuel and ignition systems seem to be working fine, I would check other things like timing advance. Have you checked your vacuum advance canister for leaks? | | | |
Entire Thread
Carb replace,
| WE b OLD | 08/06/2018 12:08 PM |
Re: Carb replace,
| Hotrod Lincoln | 08/06/2018 2:13 PM |
Re: Carb replace,
| Jon G | 08/06/2018 8:39 PM |
Re: Carb replace,
| WE b OLD | 08/06/2018 9:21 PM |
Re: Carb replace,
| fraso | 08/06/2018 11:33 PM |
Re: Carb replace,
| carbking | 08/06/2018 11:56 PM |
Re: Carb replace,
| Hotrod Lincoln | 08/07/2018 1:27 AM |
Re: Carb replace,
| carbking | 08/07/2018 2:31 AM |
Re: Carb replace,
| Hotrod Lincoln | 08/07/2018 2:52 AM |
Re: Carb replace,
| WE b OLD | 08/07/2018 10:09 AM |
Re: Carb replace,
| Volfandt | 08/07/2018 1:05 PM |
Re: Carb replace,
| panic | 08/07/2018 1:08 PM |
Re: Carb replace,
| JW51 | 08/07/2018 4:04 PM |
Re: Carb replace,
| WE b OLD | 08/07/2018 7:35 PM |
Re: Carb replace,
| Hotrod Lincoln | 08/08/2018 5:08 PM |
Re: Carb replace,
| WE b OLD | 08/08/2018 5:35 PM | |
