1 members (‘37ChevyPU),
86
3
Mod | | | Forums66 Topics128,211 Posts1,057,476 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | If it were me, I'd get a stock intake manifold and replace with one model BC properly rebuilt and jetted correctly. Make certain it is rebuilt with ethanol resistant parts and make certain the airhorn either wasn't warped or has been fixed correctly. Please note: I'm not as negative about the Rochesters as some, and while I could be wrong I believe I can come up with ways to solve some of their problems and basically I don't believe they are bad carburetors. I say BC because long ago I decided a working auto choke was much better at its job than I'd be.
Or get a Carter if you prefer, but if you drive your truck infrequently enough that your carb becomes dry I believe there is a neoprene part in there you'll become handy at replacing every year or two and if it gets dry enough it is possible you might have to replace more often than that. But hey...once you've done that a couple of times it will give you a reason to never let that carburetor become dry. If you want an example of what neoprene does when it dries out, ask any plumber or tilesetter...even an apprentice. It is one of the first things he/she learned about toilets and the reason any tilesetter worth hiring figures out what toilet bowl seals will be needed at the end of the job.
Entire Thread
Carb replace,
| WE b OLD | 08/06/2018 12:08 PM |
Re: Carb replace,
| Hotrod Lincoln | 08/06/2018 2:13 PM |
Re: Carb replace,
| Jon G | 08/06/2018 8:39 PM |
Re: Carb replace,
| WE b OLD | 08/06/2018 9:21 PM |
Re: Carb replace,
| fraso | 08/06/2018 11:33 PM |
Re: Carb replace,
| carbking | 08/06/2018 11:56 PM |
Re: Carb replace,
| Hotrod Lincoln | 08/07/2018 1:27 AM |
Re: Carb replace,
| carbking | 08/07/2018 2:31 AM |
Re: Carb replace,
| Hotrod Lincoln | 08/07/2018 2:52 AM |
Re: Carb replace,
| WE b OLD | 08/07/2018 10:09 AM |
Re: Carb replace,
| Volfandt | 08/07/2018 1:05 PM |
Re: Carb replace,
| panic | 08/07/2018 1:08 PM |
Re: Carb replace,
| JW51 | 08/07/2018 4:04 PM |
Re: Carb replace,
| WE b OLD | 08/07/2018 7:35 PM |
Re: Carb replace,
| Hotrod Lincoln | 08/08/2018 5:08 PM |
Re: Carb replace,
| WE b OLD | 08/08/2018 5:35 PM | |
