| | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | If the break-in run can't be completed without stopping and tinkering, somebody didn't do his homework right to begin with. A little valve rattle isn't going to create any permanent damage, so I add .002" to the "hot" valve lash setting and leave things that way until the initial run is done. Ditto on ignition timing- - - -tweak it by ear for the best sounding exhaust note and press on. Running at no load, it's virtually impossible to get any detonation damage, even if the timing is advanced a little too far. Use a squirrel cage blower on the radiator, or just run a garden hose over the outside of the radiator if a little extra cooling is needed. Jerry
