| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Check the voltage at the battery posts with the engine running at a fast idle. If the charging system is working properly it should be between 13.5 and 14.5, depending on the state of charge of the battery. Below 13 is very marginal- - - -below 12 means the generator or alternator is not charging. Jerry
