| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,486 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,486 | Your clutch disc could be stuck, but here is another thought: I am using a T5 from an Astro / Safari van and an 11 inch flywheel and clutch. The Astro van clutch was much smaller in diameter and naturally had the proper spline, but that clutch and pressure plate used the short throwout bearing. I used the short throwout bearing in mine. The longer one will not fit...or at least it would not fit in mine. Then I learned the linkage was too long to allow for proper adjustment. If you look at yours and if the adj nut is almost all the way to the end, you have the same situation. So what I had to do was make a new clutch connecting rod. From 5/16" rod I copied this: http://i1154.photobucket.com/albums/p535/JonGoodman/IMG_8524.jpgbut made it about 3/4" to an inch shorter and that gave me all the room I needed. You can see it here but not very well. Bending it was not much fun: http://i1154.photobucket.com/albums/p535/JonGoodman/IMG_8522.jpgGood luck! Jon
