| | | Forums66 Topics128,090 Posts1,056,020 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | I should have read your post better JT. You didnt say what you used for a primer . Just when you make your decision on your top coat make sure it is compatable with you primer..I guess I am paranoid about primers and finish coats..Had a Bad lifting experiance once..With Laquars..
HURRY UP AND WAIT 55 235 3/4
