2 members (LAROKE, baldeagle),
63
3
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Borgwarner 3sp overdrive transmission was offered up through 1972 so the solution is both cheap and easy. This gives a deep gear for starting off or load hauling but a shallow gear for highway cruising. Would be better if a 4.56 as the final would be 3.20 in OD which is a good cruising gear while the 4.11 is a bit shallow at 2.88 in OD. A 57 3100 we built with a 235 and OD was fine on level highways which covers most of Texas but not a good hill climber as the factory gear in a 57 is 3.90 which gives a 2.73 final in OD. Factory bolt on parts can fix your problem.
Evan
