| | | Forums66 Topics128,101 Posts1,056,172 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | I was able to pull my 46 2-ton engine with the transmission and without pulling anything but the hood, radiator core and shifter. I would caution against pulling any more sheet metal than necessary. You will probably break a few bolts and that can be a pain to deal with. Getting one of these is a life saver for pulling engines. https://mossmotors.com/tilt-lift-engine-hoistI have had one for years and won't pull an engine without one. You can stand it up from end to end. | | |
