| | | Forums66 Topics128,051 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | High-flex test lead wire is available in bulk on Ebay, and it comes in several colors. The difference is that the wire has dozens of strands of very fine wire and won't fatigue and break strands under the insulation as you use it. Regular primary wire is also far too stiff to be used for a tester. Jerry
