Sadly the car motor came with the truck when purchased. The diameter of your waterpump pulley does look to be a lot larger than mine. I wonder if a 1/2"pulley could be pressed onto the shaft of my pump? It looks as though that large pulley may not fit under the thermostat housing.
Sharon
