9 members (Peggy M, Otto Skorzeny, tclederman, Shade Baby, DadsFirstPickup, FAST55, Bucker, wilbur53, 1 invisible),
78
Mod | | | Forums66 Topics128,159 Posts1,056,900 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,852 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | You're talking about the "pocket bearing" that is in the back of the input shaft. It is an uncaged roller bearing that usually dumps into the case when the input shaft is removed. Heavy grease is your friend on reassembly, sticking the rollers into place as the trans is put together. It's not terribly difficult, but after assembling a few dozen of these transmissions it gets a lot easier to do. I'd just install the complete passenger car transmission and swap side plates so the shift linkage lines up correctly. Jerry
