Good afternoon Big Bolters!
I am having a brake issue and was wondering it someone here might have experienced a similar problem or know what is causing mine. So, I have my 1952 Chevy 6400 that I bought last fall.
Back then, if you used the brakes quite a bit they would get where they would hang up after stopping but would release fairly quickly once you started moving again. Then over the winter I got in to drive it one day and the brake pedal went to the floor so the first thing I checked was the fluid level in the master cylinder. I added a little (wasn't too low), then went for a drive.
For awhile, the pedal was spongy but I had brakes about 2/3 of the way down. Then it got where I had good stiff pedal, which would travel about 1/4 the way down before the pedal got stiff and you could feel braking. During this time, there were times for the first few miles that I would really have to push the pedal to stop, and it took a few more seconds than normal.
All this time, the brakes were not dragging. Today, I went for about a 10 mile drive and same thing with the pedal but when I got home and backed the truck into it's parking spot, I noticed that the brakes were hung up and now I can't push the pedal down at all. It's all the way to the top won't move and the brakes are locked up.
I would imagine once the truck cools off (overnight), the brakes will possibly release but with this new development, I can't really drive the truck.
This is the first two ton with hydrovac brakes that I have owned. Would just like to get some thoughts and recommendations on what you all would do at this point on the old trucks brake system.
Thanks!!
Kevin
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
