Very well explained Mopar..
My headlight switch is a two clicker ,,first one parking lights and second one head lights ,but,,,there are no parking lights on my vehicle and I believe it was a option to have them,, it is for dash lights only I guess
So the system i chose will not have parking lights ,, and if I had wanted them ,,then the 8 wire turn signal switch is what I would had and it would turn on the LED amber lights that are at the bottom of my headlight seal beams,,
The head light amber turn signal lights are,,,,,in my case only for turn signal and are activated thru the turning signal switch I have installed on the steeing wheel..
I will see where the 3 wires are ,, probably find the brake wire from its switch and where it goes into a loom towards the rear ..
if you think of anything more on this ,,feel free to let me know as I am a learner at this point not a teacher..thx
Directions are just another man's Opinion
