10 members (TUTS 59, Jay R, DadsFirstPickup, Ponchogl, GradyB, Leo, Jon G, walterhvogel, JW51, 1 invisible),
50
0
Mod | | | Forums66 Topics128,080 Posts1,055,944 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Faster gears will help.
Also adjust and tune your engine, 35 mph is very slow even for the stock setup. Adjust the valves. Set timing, for a likely good setting try 10 degrees advanced at an idle with vacuum advance disconnected. (Reconnect before driving)
You should easily and comfortably achieve 55 mph stock. | | |
