A higher compression ratio would likely be the result of a different head as opposed to differences in the lower end, and Beaver Bob is planning on changing the head. I've seen small block Chevy V8's used to power generators running on natural gas and I doubt they're stroked to get higher compression. One difference in the lower end may be a different cam, but that's not that likely either.
Kevin
1951 Chevy 3100 work truck
Photos
