| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Due to the lack of reinforcing ribs, that cover will leak like crazy unless it's glued down with some sort of high tech moose juice. Then every time the valves need adjusting, you'll have to go through the same leak-stopping procedure all over again. Jerry
