| | | Forums66 Topics128,092 Posts1,056,040 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | I'm thinking no easy way on the stock tranny unless he replaces it with the later design. I think the easiest is to dive into the stock third member and do a ring and pinion change to a 3.55. Today, I am buying a complete torque tube and rear axle assembly to do just this. Do a ring and pinion/bearing change in advance and get it all buttoned up then do the exchange in an afternoon. Used torque tube rear end assemblies you can get for at the most $25 some are free.
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
