7 members (Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible),
34
10
Mod | | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Possible you have some worn teeth on your flywheel that won't engage the Bendix. If the starter spins that would indicate the motor is good. With a foot starter the Bendix is mechanically engaged and since the starter spins the linkage would seem to be good. Only other part is the Bendix itself and that would not be an intermittent problem. Drop the inspection cover and check the flywheel teeth.
Ed
