| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | http://www.diyupholsterysupply.com/...tBy=&Category_Code=upholstery-springIt is just an extension spring probably sold at most hardware stores. Just find the correct length and spring rate.... or buy on line in quantity. Springs with the same OD, length and wire diameter will have approximately the same spring rate as yours. Nothing too technical for those springs. There are a couple of upholstery tips in the TIP SECTION/interiors
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
