1 members (Hotrod Lincoln),
61
2
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2017 Posts: 82 Shop Shark | | Shop Shark Joined: Nov 2017 Posts: 82 | Achipmunk I did that very thing and it did not work. The parking brake won't stay down/engaged... the wire diameter and overall diameter of the spring are the same .. so I question if the heat treating is the same as a "parts catalog " spring.... ... I wonder it I put a hardened washer between the bottom of that flat bar and the top of the spring if that would work... seems like the locking flat bar the round rod goes through is just not getting enough bite. ..... I was excited to see you too have a 52 panel !! sweet ride fella!! | | |
