1 members (1 invisible),
368
Mod | | | Forums66 Topics128,162 Posts1,057,043 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | Ala, Click on the below pic to see the spare tire set up I use on my 50. Hit the next button at upper right to see more pics. I assume the channel that is attached to your frame runs lengthwise down the center? Yes it is a swing down. After you unloosen the J bolt the tire and it's mounting bracket drops to the ground (careful, heavy) You then pull the assy out from under the bed by sliding it along the channel that is attached to frame. [img]http://thumb2.webshots.net/s/thumb1/7/35/75/114973575pUdYxE_th.jpg[/img]
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
