Mike G. If I recall correctly I had a couple
hinge holes stripped also...What I did was buy new bolts, only a little longer, and installed lock washers and nuts...I certainly would stay away from welding...JMO Bill B
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
