1 members (Phak1),
75
2
Mod | | | Forums66 Topics128,060 Posts1,055,832 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12595 10/08/2004 7:33 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Is the end you are monkeying with in the drum (see pic link below) or is this the opposite end attached to the cross bar under the bed? I assume in the drum and don't remember any special problem. Yes I used some needle nose pliers pulling the spring end back in order to hook the cable end. Is the opposite end of your brake cable still attached? If so, this might be helping create the problem for you. http://community.webshots.com/photo/111968325/118130571KWnzxp
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
