2 members (Otto Skorzeny, 3B),
131
Mod | | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2018 Posts: 128 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 128 | Darrell,
You will have to pull the headliner loose at the back by the rear window and along the drivers side. The dome light wire is attached with metal wire clips along the cab roof rail which makes it almost impossible to put the wire through. I had the same problem.
Tim Thanks. I was hoping to avoid that. I had seen where other folks were just able to fish it through. Guess it's time to tackle the headliner. | | |
