10 members (mk72, Guitplayer, cmayna, 5 Window 9434, Opelika Tom, TooMany2count, Otto Skorzeny, JW51, Gib70, 1 invisible),
76
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,053 Posts1,055,776 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Around 268 degrees of duration where the "Magnum" cam series begins is where a noticeable idle lope starts happening, and power brake and other vacuum-related problems begin. A programmable computer chip that allows for some tinkering with fuel mixture and ignition timing advance is also helpful. Jerry Yep, vacuum issues was another thing I was trying to avoid. I'd sent off my chip to be reprogramed with the new cam specs. It should be back today.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | |
