10 members (mk72, Guitplayer, cmayna, 5 Window 9434, Opelika Tom, TooMany2count, Otto Skorzeny, JW51, Gib70, 1 invisible),
76
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,053 Posts1,055,776 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Of all the H-series Comp cams, the 260 seems to offer the best compromise between power and smooth operation, at least with the 20-some ones I've personally dyno tested. Around 268 degrees of duration where the "Magnum" cam series begins is where a noticeable idle lope starts happening, and power brake and other vacuum-related problems begin. A programmable computer chip that allows for some tinkering with fuel mixture and ignition timing advance is also helpful. Jerry
