| | | Forums66 Topics128,080 Posts1,055,950 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Short answer- - - -yes the manifold will bolt on without the rings. However, there's about a 99.9% chance you'll have a vacuum leak. There are stepped-down rings designed to make the manifold/head mismatch align properly. I think some of the resto-parts places sell them, and they aren't expensive. You can also make your own step-down rings by using pieces of exhaust pipe tubing and a little tinkering. The rings don't seal- - - -they just keep the manifold and head aligned so the gasket doesn't slip out of place. Jerry
