My 39 216 pilot bearing is the needle type. A bronze bushing will not fit. I pulled it with a bearing puller as Ray stated above. Came out without any difficulty. If you're pulling out the pilot bearing, might as well replace it with a new one, and the throwout bearing as well if it is a used one.
Rick
