| | | Forums66 Topics128,079 Posts1,055,941 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | That's what I found on my 50 3/4 ton. On the 1/2 ton the ball studs are pressed in then swaged on the bottom. One of the vendors did have step-by-step instructions on their site. You have to grind away the mushroomed end and press or knock the ball studs out. On the 3600 the ball studs are held in place by a castle nut. And they are tapered. One of the vendors was selling reproduction ball studs as they tend to get egg shaped. That was my experience.
Professional Novice
