| | | Forums66 Topics128,088 Posts1,056,386 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I’m a little unsure of which question(s) you want answers too. The motor you have is a permanent magnet type. It will turn the same direction however the polarity is hooked up. The technicians you spoke with need to find another type of work. Are you changing the polarity of your truck? If so, ask how to do it on this forum and someone like Jerry and others will show you the ‘path’. I know of no “internal control components” that would be effected by the reversal. Your radio has a ‘chopper’ in its front end and I am unsure about and the polarity of your filter capacitors. That question can be asked in the other section of the electrical forum. Reversing the wires on your amp meter is a ‘no brainer’. Hope this helps.
