7 members (Buckeye998, Shade Baby, Gdads51, BarryP, JoergK., baldeagle, Jay R),
356
Mod | | | Forums66 Topics128,163 Posts1,057,072 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2018 Posts: 34 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 34 | yes I had to do this with on the driver's side with the rear plate and will probably have to do it with the front driver's side. I also had to drill out one hole in the shoe mounting plate for the adjuster pivot. I used this write-up, http://www.classicchevy.com/assets/pdf/classicchevy/20-80.pdf but couldn't find the part numbers that they list. Just wanted to make sure that the hardware kits I listed will be ok.
Marc S Houston TX 1946 Chevy 1/2 Ton
